Error - Temp sensor - I can't find the problem
zBis
Posted · Error - Temp sensor - I can't find the problem
Hello!
My ultimaker 2 displays "STOPPED - ERROR Temp sensor" when I turn it on  :(
I already checked:
- that the TEMP1 plug is in (I removed the cover at the bottom of my printer)
- the resistance of my sensor is 109 ohm (the sensor is not broken)
- I disassembled the printing head and checked that the wires were correctly plugged into the nozzle: everything is correctly plugged although my nozzle is not that clean (it is a little burnt and needs some atomic cleaning I guess... But without temp sensor, I won't be able to heat it up ^^" )
My printer was moved last weekend for a workshop and something probably moved during the transportation but I can't find the problem.
Does anyone have an idea about what's wrong?
Thanks!
        • 24 replies
