SOLVED Ubuntu 16.04 problem with Python 3.4
dcuartielles
Posted · SOLVED Ubuntu 16.04 problem with Python 3.4
If you happen to have issues running Cura after updating to Ubuntu 16.04 and the error has to do with the fact that you are running Python 3.5 instead of Python 3.4. This is the tutorial I followed in order to have Python 3.4 in parallel to Python 3.5 and in that way circumvent the issue until the Cura developers are done fixing this.
http://devmartin.com/blog/2016/04/creating-a-virtual-environment-with-python3.4-on-ubuntu-16.04-xenial-xerus/
Good luck ;-)
