Stains on alluminium bed
Melka
Posted · Stains on alluminium bed
Hi!
I have my Ultimaker 2+ for 3 weeks and enjoy it very much so far.
I recently identified some stains on the aluminium bed, just below the glass.
I tried to wash both the glass and the aluminium bed but it didn't do much.
It seems that the glass facing the aluminium got a little bit deteriorated at this specific spot (rough to the touch).
Should I be concerned ?
Thanks!
    It might reduce temperature locally a bit and you might get adhesion issues. I would try to sand it with some very smooth sanding paper. Be carefull not to bend the heater PCB.
