Posted · Can't install Cura 2.1.3 in Debian
Dear Sir/Madam,
I am currently running Cura 2.1.2 on a Dell XPS 8700 I7under Cinnamon with 32GB Of RAM
uname -a 3.16.0-4 amd64 Debian 3.16.7-ckt45-2+deb8u3 (2016-07-02) X\x86_GNU/Linux
I have had no problems running earlier versions of Cura in earlier and present versions of Debian. However Cura 2.1.3 does not install in the current version of Debian. Checking the comments I found that Python 3.4 is required. My current version of Python is 3.4.2.
When attempting the install on Debian, I get the following Engine Log.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see .
Loading polygon setting machine_disallowed_areas not implemented...
Unrecognized data type in JSON: machine_platform_offset has type array
Loading polygon setting machine_head_polygon not implemented...
Loading polygon setting machine_head_with_fans_polygon not implemented...
Unrecognized data type in JSON: machine_head_with_fans_polygon has type array
Unrecognized data type in JSON: machine_disallowed_areas has type array
Trying to override unknown setting machine_show_variants.Unrecognized
Connecting to 127.0.0.1:49674
Connected to 127.0.0.1:49674
Calling engine with: ['/opt/cura/bin/CuraEngine', 'connect',
'127.0.0.1:49674', '-j',
'/opt/cura/share/cura/resources/machines/ultimaker2plus_040.json',
'-vv']
Cura_SteamEngine version DEV
Copyright © 2014 David Braam
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
'-vv']
Your consideration and assistance if resolving this conflict is much appreciated.
Michael Tria
