Lube your UM2
fuerer_g
Posted (edited) · Lube your UM2
Every once in while, you need to lube that machine.
After applying all the lube, I run this program:
G21 ; metric valuesG90 ; absolute positioningM107 ; no fan, pleaseG28 X0 Y0 Z0G1 X30 Z5 F6000  ; move the platform to nozze or the nozze to the platform. What-ever!G1 X30 Z2 F240  ; move the last 3 mm with reduced speed - WHEW!G1 X0 Z200 F6000 ; And move back down/up again - whoohoooo!; I don't know GCode as well as others; maybe you can just do a circle?!; Move around a bit in X and Y ...G1 X0 Y0 ;G1 X223 Y0 ;G1 X223 Y223 ;G1 X0 Y223 ;G1 X0 Y0 ;; Aaaand again - cuz it was fuuhn!G1 X223 Y0 ;G1 X223 Y223 ;G1 X0 Y223 ;G28 X0 Y0 Z0 ; Back to HOMEM84 ; disable motorsM106 S0
Feel free to modify it to your specs.
CAUTION: Your printer might have different specs! Adjust all X and Y values to your printers' specs!
        • 24 replies
