It appears to be crashing from an EXC_BAD_INSTRUCTION error. See error report below
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
I still have the gut feeling this might be due to the fact that the wizard exited pre-maturely the first time it was run. For example, does it assume that all wizard settings will be defined if the wizard has been run once? In my case, I don't think the wizard actually finished all the way. Are there any hidden settings I could try deleting to go back to a default state? Uninstalling and reinstalling just gives the same message so unless it's an application problem, I have to think there's some corrupt settings somewhere it's trying to load...
Daid 303
MacOS 10.8 is Mountain lion not Lion.
The 12.12 release doesn't run on Snow Leopard, so far that is a known problem. The 12.12 release runs without problems on any 10.7 or 10.8 mac that I've seen. And the 12.12 release no longer requires anything installed on the system (it's packaged vastly different from the 12.11 release)
