Posted · PrintBite does not last.
I have a Ultimaker 2 with PrintBite on the printbed.
Worked fine at first with large prints (200mm X 60mm) but after 10 to 15 prints the print unsticks from the bed, even regular cleaning with acetone does not resolve the problem.
Small prints are OK at the moment (less than 60mm X 60mm)
A higher bed temp may be the cure but the Ultimaker 2 will only go
to 100 deg c. Can the firmware for the Ultimaker 2 be modified to
increase the bed temp ? Say to 120 deg c ?
Phil
