Marlin's Feedforward temperature parameter
phut
Posted · Marlin's Feedforward temperature parameter
I was just looking through the Marlin sources in an attempt to understand how Marlin calculates the feedforward rate.
The thing is that it doesn't appear to have the code in the calculation at all on the github sources.
Does using build-me-marlin use a set of sources that include the Kc calculation? or is it just a feel-good parameter that doesn't do anything?
