Thank you for the quick response.
I don't know why the 12.12 does not work on my linux machine, I use Ubuntu 12.04, probably I have some problem with some dependencies.
I try the development 13.01 and everything seems to go fine.
Regarding the "line 8" problem, I make some test and seems that is the "start g code" that cause the problem. If I "REM" out with ";" all the lines in the start g code and make manual homing, then the print start without any problem.
I have to make some further test in order to identify which specific command cause the block.
Daid 303
The bug that was fixed in 12.12A was only present on windows as it was in windows specific code. Not sure what's causing the linux issue.
The stop at line 8 is a bug in the printing interface. The quickest workaround would be to use pronterface.
