Posted · UM2 Top Casing Faulty / Corner floating
Hello friends,
does somebody has experianced this issue and is it a fault or within production tolerances?
My UM2 is just standing on three of its four corners, one corner is floating. I measured all casing parts and have found that the top piece does not have 90 degree angles, while the other parts have, so that the housing is slightly deformed my results in the um just standing on three feets. the floating edge has around 2-3mm spacing.
With best regards
Nnead
