Nozzle size and temperature issues
mjl1704
Posted · Nozzle size and temperature issues
I am looking at printing an object using a 0.8mm, 0.6mm and 0.4mm nozzle but I don't know what settings need to be changed accordingly. I have seen that the smaller the nozzle the lower the temperature and speed needs to be but nowhere gives any actual numbers.
Is there anything out there which gives optimal settings in Cura for the different nozzle sizes?
