communication problems
xyzlord
Posted · communication problems
i seem to have some kind of communication problem with my ultimaker since the new cura (updateted from 12.08 to 12.12A).
this is my communication log.
"Changing monitoring state from 'Offline' to 'Opening serial port'
Connecting to: COM11
Connected to: Serial(port='COM11', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from 'Opening serial port' to 'Connecting'
Recv: ?nP
Recv: =?j??Jl?J%[LZ?k%aL)?&>|Y?V?n6
Recv: J?Z?z?J?z?J?J?{?X?:&?+^>H?$P|?%?%?%H%?x??+^^J??^IJO.X?+^^X?J?j?AHJ?aHJP|@_a?&&??$
M6CL
Recv: IM^+
Recv: ?6L
Recv: I?6XH^C??&h?H
Recv: I?&(^l
Recv: x?
Recv: ?Zb?Jj?J?J?Hj??*'
Recv: joV?F?
Recv: H??J?5?-?
Send: M105
Recv: ']h?
Changing monitoring state from 'Connecting' to 'Closed'
Connection closed, closing down monitor"
i tryed upgradeing the marlin software againg but doesnt seem to make a difrence when i did.
changing the baud rate from 250000 to 115200 didnt work. swamping usb ports didnt work and neither did changing the usb cable itself for anothere one.
hopefully somebody knows what to do since im a bit at a dead end.
    Connected to: Serial(port='COM11', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0.1, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
    Changing monitoring state from 'Opening serial port' to 'Detecting baudrate'
    Trying baudrate: 250000
    Send: M105
    Baudrate test retry: 4
    Send: M105
    Baudrate test retry: 3
    Send: M105
    Baudrate test retry: 2
    Send: M105
    Baudrate test retry: 1
    Send: M105
    Baudrate test retry: 0
    Send: M105
    Trying baudrate: 230400
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Trying baudrate: 115200
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Trying baudrate: 57600
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Trying baudrate: 38400
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Trying baudrate: 19200
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Send: M105
    Trying baudrate: 9600
    Send: M105
    Changing monitoring state from 'Detecting baudrate' to 'Closed'
    Changing monitoring state from 'Closed' to 'Error: No more baudrates to...'
    this is what happens
