Posted · What is the PVA minimum clearance for assemblies on UM3?
What is the PVA minimum clearance for assemblies on UM3 when designing assemblies? I am adding holes into the assembly for water access to help facilitate support removal but after a few tries have had little success on movement after print is complete. (Last try was at .010") I currently run a Stratasys polyjet that can go down to .006" (.15mm) from wall to wall or .012" (.3mm) on diameter. Run almost exclusively at .06 layer resolution - high quality.
