How to setting Cura to be print model by T1 and print support by T0 ?
doulos0523
Posted · How to setting Cura to be print model by T1 and print support by T0 ?
Hi All
I would to print model by T1 and print support by T0 .
Now I can print model & support by T0, but I can't print model by T1 and print support by T0 .
Plz help me.
Thanks!
    Posted (edited) · How to setting Cura to be print model by T1 and print support by T0 ?
    It's right there on you screenshot!
    Select 2nd extruder as support extruder
    Hi DidierKlein
    Thanks for your reply.
    But I want to 1st extruder as support extruder and 2nd extruder as model extruder.
    On my screenshot setting, I try to print it.
    But support and model both print with 1st extruder.
    Oh ok :)then select per model settings (left bar last icon before the view icon).
    And change the head to use for the model
    More info here: https://ultimaker.com/en/resources/20411-adjusting-the-model
    Scroll down to Per model settings
    Wow~~~~
    I have succeeded
    Thank you so much !!!
    16129727_1360616053990125_1492918861_o.thumb.jpg.05997d991020ec456b922d46631c4ade.jpg
