The material combination is PLA as main material and PVA as support material. For ABS the combination is using HIPS as support material.
I'm not an expert, but PLA sticks to PVA much better than HIPS, and that may be one of the reasons why it isn't properly working.
Also, in Cura 2.X there are a lot of parameters in the "Support material" section. One of them allows you to set the distance between the support material and the model. I usually set a 0.1mm distance, but it all depends on the model and the filament type.
flowalistik 182
