Prime Tower Object
unccheezy
Posted · Prime Tower Object
I'm wondering if the prime tower object that is being printed at the same time as the main object is really needed. I'm assuming so since it's default on the main print, but I'm having trouble with the prime tower as it keeps failing the print. Thanks in advance.
        • 27 replies
