Posted · converting 2d image to 3d model problem
Dear sir,
when I import 2d image in cura for 3d model ,
it extrude it automatically but is there any way it extrude with out any angles and extrude the pixels in right angle ( 90 degree) ,in other words,
as you see in this pictures the top surface of pixels is smaller than 1111.thumb.png.403f00c0389124a783f223976a6615f4.png bottom side,
is there any way the bottom and top size of pixel will be the same size?
I used many setting in convert image menu ( like the same number for Height and base ,also I input 0 for base ) but nothing changed!!!!!
