Posted · Software setting changed the extruder direction
So my printer (reprap prusa i3) worked just fine, until one day, the extruder just started trying to eject the filament rather than push it out the hot end. I use Cura, and I believe that the issue is due to a setting that I may have changed accidentally. I printed a file that used older settings, and it printed just fine. I have seen many posts that mention switching around the wires, however, I do not think that that would fix the problem because it worked fine before. Any suggestions?
          • Heart
        • 4 replies
