Posted · Cura crashes on startup
Hello,
After I got some virus on my computer/web browser and therefor used a couple of different anti-virus programs my Cura software crashes on startup. This is most likely because some files got deleted. However it still won't work after reinstalling. I'm using Windows 10 and my specs should not be the problem.
Here the Cura.log textfile:
2017-03-12 16:51:13,415 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin FileLogger
2017-03-12 16:51:13,432 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin GCodeProfileReader
2017-03-12 16:51:13,449 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin GCodeWriter
2017-03-12 16:51:13,470 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin ImageReader
2017-03-12 16:51:13,494 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin LayerView
2017-03-12 16:51:13,513 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin LegacyProfileReader
2017-03-12 16:51:13,534 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin LocalFileOutputDevice
2017-03-12 16:51:13,556 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin MachineSettingsAction
2017-03-12 16:51:13,578 - WARNING - UM.Preferences.getValue [81]: Tried to get the value of non-existing setting cura/active_mode.
2017-03-12 16:51:13,579 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin PerObjectSettingsTool
2017-03-12 16:51:13,603 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin PostProcessingPlugin
2017-03-12 16:51:13,632 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin RemovableDriveOutputDevice
2017-03-12 16:51:13,662 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin SliceInfoPlugin
2017-03-12 16:51:13,685 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin SolidView
2017-03-12 16:51:13,709 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin CameraTool
2017-03-12 16:51:13,742 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin MirrorTool
2017-03-12 16:51:13,773 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin RotateTool
2017-03-12 16:51:13,803 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin ScaleTool
2017-03-12 16:51:13,832 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin SelectionTool
2017-03-12 16:51:13,859 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin TranslateTool
2017-03-12 16:51:13,896 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin UltimakerMachineActions
2017-03-12 16:51:13,989 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin UM3NetworkPrinting
2017-03-12 16:51:14,282 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin UpdateChecker
2017-03-12 16:51:14,294 - INFO - UpdateChecker.UpdateChecker.run [40]: Checking for new version of cura
2017-03-12 16:51:14,357 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin USBPrinting
2017-03-12 16:51:14,395 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin VersionUpgrade21to22
2017-03-12 16:51:14,430 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin VersionUpgrade22to24
2017-03-12 16:51:14,466 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin SimpleView
2017-03-12 16:51:14,496 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin WireframeView
2017-03-12 16:51:14,527 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin X3DReader
2017-03-12 16:51:14,569 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin XmlMaterialProfile
2017-03-12 16:51:14,602 - INFO - UM.PluginRegistry.loadPlugin [100]: Loaded plugin XRayView
2017-03-12 16:51:14,604 - INFO - UM.Qt.QtApplication.__init__ [90]: Command line arguments: {'file': [], 'external-backend': False, 'disable-textures': False}
2017-03-12 16:51:14,625 - INFO - UM.VersionUpgradeManager.upgrade [100]: Looking for old configuration files to upgrade.
2017-03-12 16:51:14,636 - DEBUG - UM.Backend.Backend._onSocketError [193]: Socket was unable to bind to port, increasing port number to 49675
2017-03-12 16:51:14,739 - DEBUG - UM.Backend.Backend._createSocket [208]: Previous socket existed. Closing that first.
2017-03-12 16:51:14,741 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [197]: Attempting to kill the engine process
2017-03-12 16:51:14,744 - DEBUG - UM.Backend.Backend._createSocket [208]: Previous socket existed. Closing that first.
2017-03-12 16:51:14,755 - DEBUG - UM.Backend.Backend._logSocketState [167]: Socket state changed to Listening
2017-03-12 16:51:14,846 - INFO - UM.Backend.Backend.startEngine [71]: Started engine process: C:\Program Files\Cura 2.4\CuraEngine.exe
2017-03-12 16:51:14,848 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] Calling engine with: ['C:\\Program Files\\Cura 2.4\\CuraEngine.exe', 'connect', '127.0.0.1:49675', '-j', 'C:\\Program Files\\Cura 2.4\\resources\\definitions\\fdmprinter.def.json', '']
2017-03-12 16:51:14,907 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend]
2017-03-12 16:51:14,908 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] Cura_SteamEngine version DEV
2017-03-12 16:51:14,911 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] Copyright © 2014 David Braam
2017-03-12 16:51:14,913 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend]
2017-03-12 16:51:14,914 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] This program is free software: you can redistribute it and/or modify
2017-03-12 16:51:14,916 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] it under the terms of the GNU Affero General Public License as published by
2017-03-12 16:51:14,918 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] the Free Software Foundation, either version 3 of the License, or
2017-03-12 16:51:14,919 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] (at your option) any later version.
2017-03-12 16:51:14,921 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend]
2017-03-12 16:51:14,922 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] This program is distributed in the hope that it will be useful,
2017-03-12 16:51:14,924 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
2017-03-12 16:51:14,927 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
2017-03-12 16:51:14,929 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] GNU Affero General Public License for more details.
2017-03-12 16:51:14,930 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend]
2017-03-12 16:51:14,933 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] You should have received a copy of the GNU Affero General Public License
2017-03-12 16:51:14,943 - DEBUG - UM.Backend.Backend._backendLog [89]: [backend] along with this program. If not, see .
2017-03-12 16:51:16,518 - WARNING - UM.Settings.DefinitionContainer.deserialize [202]: Unable to override setting machine_nozzle_offset_x
2017-03-12 16:51:16,521 - WARNING - UM.Settings.DefinitionContainer.deserialize [202]: Unable to override setting machine_nozzle_offset_y
2017-03-12 16:51:16,918 - DEBUG - MachineSettingsAction.MachineSettingsAction._onContainerAdded [69]: Not attaching MachineSettingsAction to punchtec_connect_xl; Multi-extrusion printers are not supported
2017-03-12 16:51:17,581 - DEBUG - MachineSettingsAction.MachineSettingsAction._onContainerAdded [69]: Not attaching MachineSettingsAction to ord; Multi-extrusion printers are not supported
2017-03-12 16:51:20,188 - DEBUG - MachineSettingsAction.MachineSettingsAction._onContainerAdded [69]: Not attaching MachineSettingsAction to ultimaker3; Multi-extrusion printers are not supported
2017-03-12 16:51:20,781 - DEBUG - MachineSettingsAction.MachineSettingsAction._onContainerAdded [69]: Not attaching MachineSettingsAction to ultimaker3_extended; Multi-extrusion printers are not supported
2017-03-12 16:51:21,041 - DEBUG - MachineSettingsAction.MachineSettingsAction._onContainerAdded [69]: Not attaching MachineSettingsAction to ultimaker_original_dual; Multi-extrusion printers are not supported
2017-03-12 16:51:22,023 - WARNING - UM.Settings.DefinitionContainer.deserialize [202]: Unable to override setting machine_nozzle_head_distance
2017-03-12 16:51:22,106 - WARNING - UM.Settings.DefinitionContainer.deserialize [202]: Unable to override setting machine_nozzle_head_distance
2017-03-12 16:51:22,119 - WARNING - UM.Settings.DefinitionContainer.deserialize [202]: Unable to override setting machine_nozzle_head_distance
2017-03-12 16:51:22,132 - WARNING - UM.Settings.DefinitionContainer.deserialize [202]: Unable to override setting machine_nozzle_head_distance
2017-03-12 16:51:29,156 - DEBUG - UM.Backend.Backend._logSocketState [171]: Socket state changed to Connected
2017-03-12 16:51:29,158 - DEBUG - UM.Backend.Backend._onSocketStateChanged [161]: Backend connected on port 49675
2017-03-12 16:51:29,161 - DEBUG - UM.Controller.setActiveView [81]: Setting active view to SolidView
Thanks in advance!
