Ultimaker original thermocouple show consistent but too low temps
Sungod3k
Posted · Ultimaker original thermocouple show consistent but too low temps
I recently got into possion of an Ultimaker original.
After I cleaned it up and it passed the Cura checks, I started printing but noticed the sweet-ish smell of burning PLA. I checked the temp and it looked normal but when I measured with my IR thermometer I got values of around 280C ca 50C higher then I intented to print with.
I printed tethered with 50C lower temp and the heating curve was not a smooth as my e3dV6 but still ok and the burning smell was gone.
There were no min temp or other temp halt errors so Im a bit puzzled by that behavior. I thought of a wrong thermistor table but I wouldnt expect that from an Ultimaker since I didnt mess with the firmware.
Anyway has someone ever seen something like this?
and secondly im thinking of switching to a normal 100k thermistor that I have laying around, that shouldnt be an issue even with the 19V electronics right?
Cheers
