Material Feeder in reverse for Ultimaker 2 Extended +.
Posted · Material Feeder in reverse for Ultimaker 2 Extended +.
I recently got an Ultimaker 2 Extended +. The material feed worked. I connected to Cura 2.5 and got firmware update. Now, the material feeds in reverse. Now the firmware version: Maintenance/version Vers:_2.4ex
I loaded Custom firmware Program Files/Cura 2.5/Resources/Firmware MarlinUltimaker2extended-plus.hex but it did not solve the problem.
I will appreciate any help getting the correct firmware or other solutions.
    I tried firmware MarlinUltimaker2extended.hex It seems to have fixed problem. Still worrying that the name is not correct.
    Posted (edited) · Material Feeder in reverse for Ultimaker 2 Extended +.
    The newest "plus" feeder is geared, thats why it's roting in the wrong direction if you use the incorrect firmware;
    If you have this white feeder, you have an Ultimaker 2 (ext) PLUS, so you need the plus firmware;
    If you have the old black feeder, like below, you need the Ultimaker (ext) firmware WITHOUT the plus in the name;oldfeeder.thumb.png.6a19a0c0e55034cbeb736fdf6ac75a89.png
