Suggestion on setting my printer
Food24
Posted · Suggestion on setting my printer
I all,
i'm using a printer WASP delta 2040 equipped with a clay extruder kit. Also, I'm trying to pring food like dough, vegetable cream, etc. I'm using Marlin firmware.
Since i have some doubt about estimated and acutal printing time, i reported below the setting of my
printer that i can read from the display of the printer.
ACC=3000 (should be 50 mm/s)
Vx,y= 20 mm/s
Ve= 5 mm/s (should be the default velocity of E-axis);
Vmax (x,y,z,E)= 250,250,250,60
Amax(x,y,z,E)=20000,20000,20000,9000,3000
Aretract=3000 (should be default acceleration of retraction)
xstep/mm(x,y,z)=+085.33
estep/mm=+0400.0
What you think about this setting ? something is wrong ?
In practice in some conditions i have from cura an estimated time of 4 min while the actual time 3 min. How can i explain this ?
Thanks
Food24
