Really bad nozzle clog
Posted (edited) · Really bad nozzle clog
Hello. I had a very long print running, went to bed with the print running fine. I woke up to see the print had lifted off of the glass, clogged the nozzle, and had been ejected from the machine. I was able to remove the nozzle, but there is still a huge block of solid, cooled plastic stuck where it should not be. Any ideas on how to safely remove this without damaging my machine?
    Posted · Really bad nozzle clog
    I've _just_ replied to another topic with the same problem. Check it out here:
    (tl;dr: heat up to 50° and over, and remove the filament (if it is PLA) carefully - if not, weep softly and order replacement parts)
    https://ultimaker.com/en/community/48990-um2-pla-clogged-up-and-clumped-around-wires-recoverable?page=1&sort=#reply-179712
