About E-step default value and its change
Food24
Posted · About E-step default value and its change
Dear all,
I'm using a printer Wasp mod. Delta 2040 equipped with clay extruder. Also, Marlin firmware.
As reported in the firmware, the default values for X,Y,Z,E axes are:
* D e f a u l t A x i s S t e p s P e r U n i t ( s t e p s / m m ) * O v e r r i d e w i t h M 9 2 * X , Y , Z , E 0 [ , E 1 [ , E 2 [ , E 3 ] ] ] * /
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 4000, 500 }
my questions are below: 7
1. The value 500 is on mm/min. if so, the acutal value should be 8.33 step/mm of filament in a time of 1 s.
2. If I leave on CURA software an -Estep=0 this means that i'm using the default value of the firmware that is 4000 ?
2. What's happen if i change the E-step value on CURA software for instance at +0400 ?
Can you help to explain me exactly how change the E-step when I modify it on CURA software ?
Thanks
Food 24
