on step motor and default max speed
Food24
Posted · on step motor and default max speed
Dear all,
I'm a little confused on the information about E-step.
On Marlin I can find that:
1. the default steps per mm are 80,90,4000,500 for X,Y,Z, E0 respectively.
2. the default Max Feed-rates are 500,500,2.5,45 for X,Y,Z;E0, respectively.
It is not clear for me the difference between the two information.
How is possible that the default values for E-axis is greater than its maximum rate ?
Can you explain me what exactly means these two information ?
Thanks
Food 24
    Check out the official Marlin documentation:
    https://github.com/MarlinFirmware/MarlinDocumentation
    For documentation on the configuration files can be found here:
    https://github.com/MarlinFirmware/MarlinDocumentation/blob/master/_configuration/configuration.md
    And, finally, regarding your specific questions, look here:
    https://github.com/MarlinFirmware/MarlinDocumentation/blob/master/_configuration/configuration.md#default-steps-per-mm--
    Hope this helps.
