Using AppImage and Pluging
stampedeboss
  • 1 year later...
Posted · Using AppImage and Pluging
This is an important question. I need to install the "Malyan/Monoprice USB workaround" plugin and have not found out how yet. If I find out, I'll try to post a reply here. It's a pity that no one has seen fit to respond.
