Problem using BFB GCode Parfum with 3D pattern
Lookid
Posted · Problem using BFB GCode Parfum with 3D pattern
Hello,
I have a problem using 3D pattern using BFB GCode Parfum.
My machine only reads .bfb.
I am trying to print a single cube with 20% infill, but as you can see in the images, the pattern generated when I change the GCode Parfum to BFB (and this is the only change) is totally not the one expected.
I tried all the GCode Parfum and this is the only one having this problem.
BFB GCode Parfum
All others GCode Parfum
Could you please help me ?
Thank you
