i have Ultimaker 2 Extended with Olsson block
There are two things you can do:
The first is to add another Ultimaker 2 Extended (name it eg Ultimaker 2 Extended 0.3), and tell Cura you don't have an Olsson block. You can then go to "Manage Printers...", open the "Machine Settings" and set the "Nozzle size" to 0.3 mm.
The more complicated way is to open your configuration folder (Help -> Show configuration folder). There should be a folder named "variants" there. In that folder, create a file named "ultimaker2_extended_0.3.inst.cfg" with the following contents:
[general] name = 0.3 mm version = 2 definition = ultimaker2_extended [metadata] author = Ultimaker type = variant setting_version = 1 [values] machine_nozzle_size = 0.3 machine_nozzle_tip_outer_diameter = 0.8
ahoeben 1,986
Do you have an Ultimaker 2 Extended with Olsson block upgrade, or an Ultimaker 2 Extended+ ? There's a difference.
