Minimum Layer Time
dd123c5
Posted · Minimum Layer Time
Hello everyone i have been really enjoying the new cura update 2.6 but i have been having a small issue with the minimum layer time setting when used with the lift nozzle setting whenever i attempt to print very large print with a very small top (as in no room to make small pillars to allow cooling) and i have minimum speed set to zero and minimum layer time set to 30 the and also having the lift nozzle box checked it will lift the nozzle for the amount of time it takes to move away from the print and just goes right back to printing without actually waiting the rest of the amount of layer time does anyone have any ideas as why this is not working or is that how it is ment to work and you just cant print small things with cura
