Changing hotkeys?
whiteglint
Posted · Changing hotkeys?
Hi all,
I have Cura 2.6 installed on my macbook and trying to navigate with panning and rotating is infuriating since it does not seem to support gestures. I can use the arrow keys to rotate but it triggers a thumping alert sound to occur for each small rotation. It would be so much better if i could just manually configure the keys to zoom, pan, and rotate. Is there anyway to do this?
