Heat bed temp sensor input
thereza
Posted · Heat bed temp sensor input
I've connected the heat bed to the 2nd temp input but just read that it should have been the 3rd. not wanting to move and resolder the temp sense resistor, i wanted to see if this is the required change in software to make it work with the second temp sensor..
this is from pins.h. So change
#define HEATER_BED_PIN 4
#define TEMP_BED_PIN 10
#define HEATER_1_PIN 3
#define TEMP_1_PIN 9
to
#define HEATER_BED_PIN 3
#define TEMP_BED_PIN 9
#define HEATER_1_PIN 4
#define TEMP_1_PIN 10
Is there anything else that I would need to change?
Reza
