paulsroom 2
From various investigations, I believe that the current specifications of the feeder spring are
Outside diameter: 7.5mm
Inside diameter: 5mm
String diameter: 1.2mm
Height: 20mm
But I believe that there has also been a slightly weaker spring fitted to UM2 at some point
Inside diameter: 4.5mm
Height: 16mm
Would this weaker spring still work okay and lessen the occurrence of filament getting stuck in the feeder?
