13.06.5 debian hangs on startup
ianeagland
Posted · 13.06.5 debian hangs on startup
Hi
I have just installed Cura from the package on Ubuntu 10.04 LTS.
I get the blue splash screen and then nothing happens, the splash screen just stays on the desktop.
Any ideas how I can get it to run?
Regards
Ian
    Hi Ian
    You can open a gnome-terminal then just type the following
    /usr/bin/cura
    If ever it is another path, type which cura should tell you.
    As a naive guess, try to upgrade with apt-get update followed by apt-get upgrade.
    Sometime ago I ran into trouble due to the python or pypy version (see mine below).
    But it currently runs fine on my Ubuntu 12.04. Only the splash screen seems empty -- when it stays long enough so I can see it. Really not an issue for me, don't make it slower! ;)
    BTW a few more useful console commands to provide more information.
    Daid, I saw no "--verbose" nor "--help" option to Cura, they could prove useful maybe.
    I also don't know if python/pypy is still in use (I guess so for the GUI).
    lsb_release -a
    LSB Version: core-2.0-ia32:core-2.0-noarch:core-3.0-ia32:core-3.0-noarch:core-3.1-ia32:core-3.1-noarch:core-3.2-ia32:core-3.2-noarch:core-4.0-ia32:core-4.0-noarch
    Distributor ID: Ubuntu
    Description: Ubuntu 12.04.2 LTS
    Release: 12.04
    Codename: precise
    pypy --version
    Python 2.7.2 (1.8+dfsg-2, Feb 19 2012, 19:16:05)
    [PyPy 1.8.0 with GCC 4.6.2]
    python --version
    Python 2.7.3
    cura && lsof | grep cura | awk '{print $9}' | grep -v /dev/
    /volatile
    /bin/dash
    /lib/i386-linux-gnu/libc-2.15.so
    /lib/i386-linux-gnu/ld-2.15.so
    /usr/bin/cura
    cheers,
    Jeremie
    Many thanks Jeremie
    I can now see an error. The update/upgrade did not solve the problem, error remains the same.
    ian@ian-desktop:/usr/bin$ cura
    Traceback (most recent call last):
    File "/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14614, in <lambda>
    lambda event: event.callable(*event.args, **event.kw) )
    File "/usr/share/cura/Cura/gui/splashScreen.py", line 16, in DoCallback
    self.callback()
    File "/usr/share/cura/Cura/gui/app.py", line 41, in afterSplashCallback
    from Cura.gui import mainWindow
    File "/usr/share/cura/Cura/gui/mainWindow.py", line 16, in <module>
    from Cura.gui import sceneView
    File "/usr/share/cura/Cura/gui/sceneView.py", line 26, in <module>
    from Cura.gui.util import previewTools
    File "/usr/share/cura/Cura/gui/util/previewTools.py", line 13, in <module>
    from Cura.gui.util import opengl
    File "/usr/share/cura/Cura/gui/util/opengl.py", line 20, in <module>
    from OpenGL.GL import shaders
    ImportError: cannot import name shaders
    One for Daid I guess.
    I don't want to upgrade Ubuntu as I have linuxCNC on the same computer and they don't support 12.04 yet.
    Regards
    Ian
    Tried to install this on Mint 13 (12.04) however i get a Blue startup window and then hangs with this error
    File "/usr/lib/python2.7/dist-packages/wx-2.6-gtk2-unicode/wx/_core.py", line 13535, in <lambda>
    self.callback()
    File "/usr/share/cura/Cura/gui/mainWindow.py", line 8, in <module>
    from Cura.gui import configBase
    File "/usr/share/cura/Cura/gui/configBase.py", line 7, in <module>
    from wx.lib.agw import floatspin
    ImportError: No module named agw
    Also the file is listed as 13.06.3-1 when installing
    mttr, your version of wxPython is too old for Cura (no idea which minimal version is needed)
    Hi Daid
    Do you know how to solve my problem. Error report posted above on 6th July.
    Regards
    Ian
    Oh, yes, sorry, that "missing shaders" error is from the Python-OpenGL package, most likely the version on your machine is too old for Cura.
    FYI on my system I run fine with version 2.8.12
    sudo apt-show-versions |grep -i python|grep wx
    python-wxgtk2.8/precise uptodate 2.8.12.1-6ubuntu2
    python-wxtools/precise uptodate 2.8.12.1-6ubuntu2
    python-wxversion/precise uptodate 2.8.12.1-6ubuntu2
    Check http://stackoverflow.com/questions/9212234/no-module-named-agw-aui
