Posted
(edited)
· Cura 3.4 no support generated on first layer
I can confirm this finding. There is no support generated on the first layer for objects like a hollow half sphere. It can't be the multiplied layer height of the support as the first support appears on layer 3 for build material layer height 0.1mm and support layer height 0.2mm.
However, there is a workaround: disable the option "brim only on the outside" (so it also prints a brim on the inside) and then support is generated from the first layer on.
Edited by Dim3nsioneer
Dim3nsioneer 558
Edited by Dim3nsioneerLink to post
