Peek Replacement
Posted · Peek Replacement
As I mentioned in my other topic about extruder issues I had sheered my brass pipe off inside my peek. I was unable to remove it and ended up having to find a replacement. I decided to go with this
http://www.makergear.com/products/groovemounts
and the 36mm brass pipe from makergear as well. Well, it took some thinking and some sanding but I got the piece in and it seems to be working really well so far. I haven't had time to test extensively yet, but it is promising. I'll update and post results and the process a little later on, hopefully I'll have refined it some by then and it won't look quite so slapped together!
