Gcode 3.4.1
Guisao5
Posted · Gcode 3.4.1
The gcode does not work as expected in Cura 3.4.1
It's like this in the Start code
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G90; EXTRUSORA NO POSICIONAMENTO ABSOLUTO
M83; EXTRUSORA NO MODO RELATIVO
M106 S255; LIGA VENTILADOR
G4 P500; PAUSA MOVIMENTO
M106 S0; LIGA VENTILADOR
M140 S{print_bed_temperature}; TEMPERATURA DA MESA
M190 S{print_bed_temperature}; AGUARDA MESA AQUECER
M109 S100; FAZ AQUECIMENTO DO BICO
M104 S{print_temperature}; FAZ PRE AQUECIMENTO DO BICO
M402
G28; HOME GERAL
M400
G29 V4 T ; AUTO NIVELAMENTO
M400
G1 X1 Y1 Z0.8 F1000; VAI PRA PONTO DE PURGA
M109 S{print_temperature}; FAZ AQUECIMENTO DO BICO
G92 E0; RESETA EXTRUSOR
G1 X1.0 E9.0 F1000.0 ; PURGA
G1 X100.0 E12.5 F1000.0 ; PURGA
M117 IMPRIMINDO...
M400
G1 E-6.0000 F4200
G1 Z0.600 F3000
T0
Why are you leaving like this?
;FLAVOR:Marlin
;TIME:35423
;Filament used: 85.3195m
;Layer height: 0.2
;POSTPROCESSED
;ChangeAtZ instances: 1
;Generated with Cura_SteamEngine 3.4.1
▶︎M190 S115 ◀︎
▶︎M104 S250◀︎
▶︎M109 S250◀︎
M82 ;absolute extrusion mode
;Sliced at: Thu 12-07-2018 15:09:50
;Basic settings: Layer height: 0.2 Walls: 1.5 Fill: {fill_density}
;Print time: 09:50:23
;Filament used: [85.32]m [225.7392328125]g
;Filament cost: [0]
;M190 S110 ;Uncomment to add your own bed temperature line
;M109 S225 ;Uncomment to add your own temperature line
M140 S110; TEMPERATURA DA MESA
M190 S110; AGUARDA MESA AQUECER
M104 S225; FAZ PRE AQUECIMENTO DO BICO
M402
G28; HOME GERAL
M400
M400
M109 S225; FAZ AQUECIMENTO DO BICO
M117 IMPRIMINDO...
M400
G1 E-6.0000 F4200
G1 Z0.600 F3000
T0
G92 E0
G1 F1500 E-6.5
    Because you use old, deprecated replacement patterns. Use “material_bed_temperature” instead of “print_bed_temperature”, and “material_print_temperature” instead of “print_temperature”.
    Could you tell me if you can remove these lines?
    ;M82 ;absolute extrusion mode
    ;M190 S105 ;Uncomment to add your own bed temperature line
    M140 S105; TEMPERATURA DA MESA
    M190 S105; AGUARDA MESA AQUECER
    M402
    G28; HOME GERAL
    M400
    M400
    M117 IMPRIMINDO...
    M400
    G1 E-6.0000 F4200
    G1 Z0.600 F3000
    T0
    ▶︎ E0◀︎
    ▶︎ F1500 E-6.5◀︎
    ;LAYER_COUNT:654
    Hello
    I also have a problem with the code ahead of the 'start code'
    My machine is a UMO with heated bed and dual extruder. I use the nozzles to keep different materials loaded, rather than as dual extrusion. I also need to keep the working area at maximum, so have created a single extruder machine that uses the second nozzle. However, the code at the top (shown in bold):
    ;FLAVOR:Marlin
    ;TIME:18013
    ;Filament used: 7.09843m
    ;Layer height: 0.15
    M190 S60
    M104 S210
    M109 S210
    G21 ;metric values
    G90 ;absolute positioning
    ...seems to get both nozzles to heat up.
    How can I stop this code being written?
    Thanks, Colin
    Make sure your startgcode contains the literal strings “{material_print_temperature}” and “{material_bed_temperature}”, even if it is in a comment. Cura will see this as a preheating sequence, and won’t add one of its own.
    Thanks, that works perfectly.
    Here is my start code for reference:
    T0 ;Switch to the 1st extruder
    M104 S0 ;switch off nozzle 0
    T1 ;Switch to the 2nd extruder
    M190 S{material_bed_temperature} ;Set bed temp and wait to reach temp
    M109 S{material_print_temperature} ; Set extruder temp and wait to reach temp
    G4 S20 ;Wait for extruder temp to stabilise
    G21 ;metric values
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F9000 ;move the platform down 15mm
    G1 F200 E15 ;extrude 15 mm of feed stock
    G1 F9000
    ;Put printing message on LCD screen
    M117 Printing...
    I have also used this code when using the first extruder, but with the nozzle numbers reversed in the first 3 lines.
    Note that I have added a pause (G4 in line 6) to allow the extruder temperature to stabilise, and increased the length of the priming extrusion.
    I am now using the 'Printing Temperature - Initial Layer' parameter, so the extruder heat-up line can be changed to:
    M109 S{material_print_temperature_layer_0}
