Could you tell me if you can remove these lines?
;Generated with Cura_SteamEngine 3.4.1
;M82 ;absolute extrusion mode
;M190 S105 ;Uncomment to add your own bed temperature line
;M109 S225 ;Uncomment to add your own temperature line
G90; EXTRUSORA NO POSICIONAMENTO ABSOLUTO
M83; EXTRUSORA NO MODO RELATIVO
M106 S255; LIGA VENTILADOR
G4 P500; PAUSA MOVIMENTO
M106 S0; LIGA VENTILADOR
M140 S105; TEMPERATURA DA MESA
M190 S105; AGUARDA MESA AQUECER
M109 S100; FAZ AQUECIMENTO DO BICO
M104 S225; FAZ PRE AQUECIMENTO DO BICO
M402
G28; HOME GERAL
M400
G29 V4 T ; AUTO NIVELAMENTO
M400
G1 X1 Y1 Z0.8 F1000; VAI PRA PONTO DE PURGA
M109 S225; FAZ AQUECIMENTO DO BICO
G92 E0; RESETA EXTRUSOR
G1 X1.0 E9.0 F1000.0 ; PURGA
G1 X100.0 E12.5 F1000.0 ; PURGA
M117 IMPRIMINDO...
M400
G1 E-6.0000 F4200
G1 Z0.600 F3000
T0
▶︎ E0◀︎
▶︎ F1500 E-6.5◀︎
;LAYER_COUNT:654
ahoeben 1,992
Because you use old, deprecated replacement patterns. Use “material_bed_temperature” instead of “print_bed_temperature”, and “material_print_temperature” instead of “print_temperature”.
Guisao5 0
You did it right, thank you very much.
