Cura Won't Start on Windows 10
seg9585
Posted · Cura Won't Start on Windows 10
Hello,
I cannot get any version of Cura (current or past) to start on my computer.  I have tried 3.4.1, 3.4, and several older versions back to 2.7.
For every attempt I have completely deleted the AppData folders in Local and roaming and did a clean install.  The splash screen appears and then the User Agreement dialog shows up completely empty, then the program closes.
I have attached my Cura log and my Windows 10 Pro info.  Could really use some help with this one...
cura.log
    Integrated Intel HD 620 graphics card within a Lenovo X1 Carbon laptop.  Drivers fully up to date.
    I can run Solidworks and Adobe Premiere on this computer just fine.
    • 4 months later...
    seg9585 did you manage to fix the issue? I happen to also have the exact same issue and the same generation of x1 carbon (but with a i7 7500). Cura crashes and closes at the user agreement dialog box after I upgraded to Cura 3.6 from Cura 3.5. Cura 3.5 and before used to work but now it doesn't. I tried version 2.7 too, but now it closes a few seconds after launching. Before trying any version, I would uninstall, delete the program folder and clear Cura folders in %appdata%, still doesn't work. Would appreciate any feedback.
