Ultimaker 3 Wi-Fi issue
gkoginov
Posted · Ultimaker 3 Wi-Fi issue
Hi All,
I have an issue with my brand new Ultimaker 3, specifically with setting up the wifi connection. I have so far tried with 3 different networks, two local at work and cellular over a mobile hotspot.
The printer was able to only connect to one of the local office networks, but sadly I cannot actually use it for internal reasons.
Is there any way to troubleshoot why UM3 is failing to connect to my other networks? Are there any requirements that I have to enable through the router? The only error I get is that the connection attempt failed.
Thank you!
