Posted (edited) · Recommended settings for PCL filament?
I'm using the Ultimaker Cura 2+, and trying to print with 2.85mm PCL without much luck so far.
I was recommended 100-110 degrees print head on a 20%-30% speed but I'll have to adjust some more..
"Please rechange your teflon throat tube ,use a new nozzle and adjust print speed 20%~30%." was the quote by seller.
Anyone had success with this material and care to share their settings? The printer I'm using is far away and I have it for a limited time when I book it, so I want to be as efficient as possible when testing
Edited by DST
    • 6 months later...
