UM S5 active levelling
yvichrome
Posted · UM S5 active levelling
Hi all,
 is there a way to start the active levelling on the S5? (Other than starting a print job and the abort it)?
I haven't found it in the menu ... (I would like to have it though, to check a new manual levelling.
In the troubleshooting section of the UM website it says ... " Restart the active leveling process. " and " After this, you can start the active leveling again." - But I don't know how .
Thanks - Yvonne
    I did not find a way to start it manually, so either I overlooked it or it is not available through the menu.
    But why do you need it? I find that leveling in general is seldomly needed (except if you remove the glass plate after every print).
    • Thanks 1
    Yes  ...
    you're probably right and I only miss it much,beacuse it was there before .
    I use it a lot when I train new users on the UM and let the perform a manual levelling, to check afterwards.
    But in real life - you re right - its not so often needed - ?
    Nevertheless, thanks for looking it up !
        • 56 replies
        • 29 replies
