Nicolinux 288
I did not find a way to start it manually, so either I overlooked it or it is not available through the menu.
But why do you need it? I find that leveling in general is seldomly needed (except if you remove the glass plate after every print).
yvichrome 2
Yes ...
you're probably right and I only miss it much,beacuse it was there before .
I use it a lot when I train new users on the UM and let the perform a manual levelling, to check afterwards.
But in real life - you re right - its not so often needed - ?
Nevertheless, thanks for looking it up !
