Youmagine "new items posted" thread order
mastory
Posted · Youmagine "new items posted" thread order
If it can be done, this thread should be chronologically reversed so the newest post is always at the top. Not complaining, trying to be constructive...
Matt
    That would make sense... I'm not sure if it's possible to change the order, though. I had a quick look, but it seems that if it's possible, it would be a global setting for the entire forum. That's a bit too much. Maybe we need to make a little widget that shows the latest designs which you can click away once you've seen it.
