Speed control for Surface Mode
lolitodubateau
Posted · Speed control for Surface Mode
Is there a way to control the print speed in Cura for Surface Mode (I am using Cura 3.4.1 on Windows-10)?
You can see from the screenshots that any speed change does not affect the print time. In fact, the gcode generated is exactly similar (besides the comment section) when the speeds are all set to 40mm/s or 20mm/s. On my Rostock v3 printer, the part printed in surface mode always prints at ~10mm/s, independently of the speed settings.
Surface20_RoundedSquare40x8mm.gcode
Surface40_RoundedSquare40x8mm.gcode
RoundedSquare40x8mm.stl
        • 21 replies
