Z Hop tips
CiroPg
Hello my friends I am use Cura for one year and now I have one question about possability. Some time I am play with Z hop options and I think that wood be a great when I can turn option only for out object and also with top and bottom layer :) It will be a little bit nice part and if small line is inside the object never mind, it is not visible on the final part. What you think about that?
Cheers, Aleksandar
        • 27 replies
