Ok thanks for this...! I definitely have the wrong version....From what I've read, Netfabb isn't all that great either. Until the newer version comes out, everyone is generating a code in Netfabb, saving it and loading it up in RepG to print it. To print it in RepG you have to modify the software somewhat. Is that a close overview? thanks much again..!
The printing from NetFabb is broken right now. But the slicer (Model->GCode) is a piece of wonder (as far as I understand, I don't have NetFabb). And even printing from RepG is not the best way, printing from PrintRun is even more stable. RepG itself doesn't do any slicing, it uses Skeinforge to do that. So you got a bunch of different steps (modeling -> slicing -> printing) and all those steps have different software options. With advantages and disadvantages.
Could you recommend a software & firmware to use then with links? Any help would be greatly appreciated....
The link for Marlin firmware is here: [do not use->]https://github.com/bkubicek/Marlin [use this one->]
https://github.com/ErikZalm/Marlin
Easy version here:
http://daid.eu/~daid/marlin_build/
The link for printrun pronterface is here:
https://github.com/kliment/Printrun
Easy version here:
http://koti.kapsi.fi/~kliment/printrun/
Warning / disclaimer: There is some fiddling to get these things set up and running. You will need to read the instructions if you plan on doing it the hard way.
Wrong! where did you find that link? Because you should point to the ErikZalm version, that's the latest and most stable version.The link for Marlin firmware is here:https://github.com/bkubicek/Marlin
You know, I thought there was a newer version than the one I linked to, but I couldn't find it. It's hard to keep track of all these Marlins sometimes. :?
I just noticed I might sounded a bit harsh, was not the intention. It is confusing, but ErikZalm is maintaining a stable up to date version in his v1 branch (which is the default branch you see)
Daid 303
In my oppinion? Don't use RepG at all.
There are quite a few software options, RepG being one of them. But you should be using the RepG from
http://software.ultimaker.com/
on the ultimaker.
See:
http://wiki.ultimaker.com/Software_setup_guide
which offers 3 options (one of those made by me, so I'm not the right person telling what to use
