Posted · Cura 3.6 crashes when you select File Menu Item
I have uninstalled and reinstalled several time.  I have tried deleting the Cura folder in app data for the user.
The program will load but when the user clicks file it crashes with the data below.
The user is a local administrator on the machine.  When I run it as my user it works.
The description for Event ID 1000 from source Application Error cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Cura.exe
0.0.0.0
5bd2dc78
ig75icd64.dll
10.18.14.4889
5a32f45f
c0000005
000000000054b0b5
31c0
01d49620e5978fc3
C:\program files\Ultimaker Cura 3.6\Cura.exe
C:\windows\system32\ig75icd64.dll
3de07b13-0214-11e9-b250-e8b1fc14a582
The handle is invalid
