ratti 0 Posted September 2, 2013 in Cura compiling Hello, and thanks you very much for this really nice program you created. I'm having some problems compiling the source of Cura that i got from github. I'm compiling with g++ but the line you provided in the makefile doesn't work. I have tried many other ways, but there is always something that doesn't work properly. So i just wanted to know if there are some libraries i need to add, or some specific things i have to do. Maybe it's my fault, so i'm just checking. Thanks, Ratti ps- I'm talking about the Slicing Engine, not about the GUI Share this post Link to post Share on other sites
Daid 260 Posted September 2, 2013 in Cura compiling Which OS? Share this post Link to post Share on other sites
ratti 0 Posted September 4, 2013 in Cura compiling Sorry, i should have told you this from the first post. I work on windows, but the g++ has given me errors both on linux and windows. Thanks Daid, Ratti Share this post Link to post Share on other sites
Daid 260 Posted September 16, 2013 in Cura compiling (Back after 2 weeks vacation) Still having issues? Could you show me the compiler output? Share this post Link to post Share on other sites
ratti 0 Posted October 17, 2013 in Cura compiling Well i still have some compiling problems...trying to do it with codeblocks and the gnu gcc compiler. Here is the compiler log(two errors). I'm obviously missing something, just can't figure out what. C:\...\CuraEngine-master\utils\intpoint.h||In member function `int32_t Point3::vSize()':|C:\...\CuraEngine-master\utils\intpoint.h|60|warning: converting to `int32_t' from `double'|C:\...\CuraEngine-master\utils\intpoint.h||In function `int32_t vSize(const Point&)':|C:\...\CuraEngine-master\utils\intpoint.h|108|warning: converting to `int32_t' from `double'|C:\...\CuraEngine-master\utils\intpoint.h||In member function `Point PointMatrix::apply(Point) const':|C:\...\CuraEngine-master\utils\intpoint.h|170|warning: passing `double' for converting 1 of `ClipperLib::IntPoint::IntPoint(ClipperLib::long64, ClipperLib::long64)'|C:\...\CuraEngine-master\utils\intpoint.h|170|warning: passing `double' for converting 2 of `ClipperLib::IntPoint::IntPoint(ClipperLib::long64, ClipperLib::long64)'|C:\...\CuraEngine-master\utils\intpoint.h||In member function `Point PointMatrix::unapply(Point) const':|C:\...\CuraEngine-master\utils\intpoint.h|175|warning: passing `double' for converting 1 of `ClipperLib::IntPoint::IntPoint(ClipperLib::long64, ClipperLib::long64)'|C:\...\CuraEngine-master\utils\intpoint.h|175|warning: passing `double' for converting 2 of `ClipperLib::IntPoint::IntPoint(ClipperLib::long64, ClipperLib::long64)'|C:\...\CuraEngine-master\utils\intpoint.h||In function `Point centerOfMass(const ClipperLib::Polygon&)':|C:\...\CuraEngine-master\utils\intpoint.h|213|warning: passing `double' for converting 1 of `ClipperLib::IntPoint::IntPoint(ClipperLib::long64, ClipperLib::long64)'|C:\...\CuraEngine-master\utils\intpoint.h|213|warning: passing `double' for converting 2 of `ClipperLib::IntPoint::IntPoint(ClipperLib::long64, ClipperLib::long64)'|C:\...\CuraEngine-master\modelFile\..\utils\floatpoint.h||In member function `Point3 FMatrix3x3::apply(FPoint3)':|C:\...\CuraEngine-master\modelFile\..\utils\floatpoint.h|79|warning: passing `double' for converting 1 of `Point3::Point3(int32_t, int32_t, int32_t)'|C:\...\CuraEngine-master\modelFile\..\utils\floatpoint.h|79|warning: passing `double' for converting 2 of `Point3::Point3(int32_t, int32_t, int32_t)'|C:\...\CuraEngine-master\modelFile\..\utils\floatpoint.h|79|warning: passing `double' for converting 3 of `Point3::Point3(int32_t, int32_t, int32_t)'|C:\...\CuraEngine-master\slicer.h||In member function `void SlicerLayer::makePolygons(OptimizedVolume*, bool, bool)':|C:\...\CuraEngine-master\slicer.h|126|warning: converting of negative value `-0x000000001' to `unsigned int'|C:\...\CuraEngine-master\slicer.h|127|warning: converting of negative value `-0x000000001' to `unsigned int'|C:\...\CuraEngine-master\slicer.h|191|warning: converting of negative value `-0x000000001' to `unsigned int'|C:\...\CuraEngine-master\slicer.h|192|warning: converting of negative value `-0x000000001' to `unsigned int'|C:\...\CuraEngine-master\slicer.h|196|warning: converting of negative value `-0x000000001' to `unsigned int'|C:\...\CuraEngine-master\slicer.h|197|warning: converting of negative value `-0x000000001' to `unsigned int'|C:\...\CuraEngine-master\infill.h||In function `void generateLineInfill(const ClipperLib::Polygons&, ClipperLib::Polygons&, int, int, int, double)':|C:\...\CuraEngine-master\infill.h|69|error: 'class std::vector<int64_t, std::allocator<int64_t> >' has no member named 'data'|C:\...\CuraEngine-master\bridge.h||In function `int bridgeAngle(SliceLayerPart*, SliceLayer*)':|C:\...\CuraEngine-master\bridge.h|56|warning: converting to `int' from `double'|C:\...\CuraEngine-master\support.h||In function `void generateSupportGrid(SupportStorage&, OptimizedModel*)':|C:\...\CuraEngine-master\support.h|87|error: 'class std::vector<SupportPoint, std::allocator<SupportPoint> >' has no member named 'data'|C:\...\CuraEngine-master\gcodeExport.h||In member function `void GCodePlanner::forceMinimalLayerTime(double, int)':|C:\...\CuraEngine-master\gcodeExport.h|533|warning: converting to `int' from `double'|C:\...\CuraEngine-master\gcodeExport.h|540|warning: passing `double' for converting 1 of `void GCodePlanner::setExtrudeSpeedFactor(int)'| Thanks for the future help Share this post Link to post Share on other sites
Daid 260 Posted October 18, 2013 in Cura compiling Looks like your version of the compiler is missing support for the data() function in std::vector: http://www.cplusplus.com/reference/vector/vector/data/ Share this post Link to post Share on other sites
