removal of capacitive sensor board Ultimaker 3
Christian_
Posted · removal of capacitive sensor board Ultimaker 3
Hi there!
How can I remove the capacitive sensor board on an Ultimaker 3? Can I bend up the clamps/contacts or is there any other solution?
Thank you for an answer!
Best greetings
Christian
