Posted (edited) · Ultimaker Electronics board v2.1.4 used for sale
Listing here
http://ebay.us/ZAXe9H?cmpnId=5338273189
compatible with the Ultimaker 2+/2Ext+, Ultimaker 2 (inc Go and Extended variants), and the Ultimaker Original+.
Wanted to give you guys first dibs on it if anyone desperately needed one. Need to be flashed before use as I had VERY custom firmware on it. I replaced mine with a Duet2 Maestro. All working with zero issues. Does have some browning around the stepper drivers but this seems to be common with these boards after some use.
Edited by Gencab
    • 2 weeks later...
    Posted · Ultimaker Electronics board v2.1.4 used for sale
    7 hours ago, 3dprinting_guy said:
    Found one locally.
    Awesome! Flashing the firmware is a simple affair. Firmware can be downloaded from Ultimaker or you can use a custom one like Amedee's awsome firmware builder found here
    Flash in connect the board to your PC via USB and flash in Cura: System -> Maintenance -> Firmware update
